Difference in power from 14b to s16g
Notractionfwd
Nov 1, 2009
San Diego, California
I want to upgrade to a small 16g from a 14b, is there a difference in power & spool,I like my 14b but I want alittle more topend.
Here is a list I found. Just to show you some comparison. Have you thought about a evo 3 16g?
Flow Rates @ 15psi:
TDO4-9B-6CM2 265 CFM
TDO5-12A-8CM2 320 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
TDO5H-14B-6CM2 405 CFM
TDO5H-14G-8CM2 465 CFM
TDO5H-16G-7CM2 505 CFM
TDO5H-16G-10CM2 505 CFM
TDO6-17C-8CM2 550 CFM
TDO6H-20G-14CM2 650 CFM
TDO7S-25G-17CM2 850 CFM
TFO8L-30V-18CM2 1200 CFM
Max Output:
TD05-14B (stock 1st gen) 275-300hp @ 21 psi
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
T25 (stock 2nd gen) 235-250hp @ ?? psi
T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi
T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi
If there is nothing wrong with your 14b, i wouldnt take it off just yet and upgrade. I would suggest saving up and doing your supporting mods, ie,...fuel pressure regulator, fuel pump, a data logger, exhaust, boost controller,boost guage...so on and so on. Your profile says your bone stock.With those mods and a little more boost alot of people are making great power with a 14b. I have a small 16g ported, and i love it....but you really should spend the money on other mods before just putting on a turbo and turning the boost up. Unless you want to spend some cash on a rebuilt engine....good luck.
I'd say stick with the 14b for now......I've had plenty of fun and success with mine....but I'm eager to try out a 16g as well.
Well i have an evo big 16g and i love it. you should really get supporting mods like said earlier. I rebuilt my motor with the evo 3 big 16g though so i didnt really get alot of add ons. just boost gauge 3" full exauhst no cat, stock fuel and boost regulator and a fp255lph fuel pump. bored .20 over port n polished head and fidanza 2.1 kevlar clutch kit. and it hasnt done me wrong. except a few relays acting up and my abs going out.
