97GSX, need a turbo...14b,s16g???
DSMnOOb00
903
4
Apr 29, 2006
FRESNO, California
what kind of turbo should i get for a daily GSX driver? im looking at a 14b off a older eclipse, but i really dont know what to go for, im looking to get small time mods, somthing like 300hp ish...
I say you go with the evoIII 16g. Cheap, reliable, and packs a punch! You will go over your 300hp mark but you will not be disapointed. The best bang for the buck turbo out there. Period. Hope this helps. Good Luck :thumb:
I agree with ypnas777. The Big 16g is a great turbo for the horsepower range you're looking at.
If you never want to go over 300-350whp then your fine. You might also want to get a turbo that will give you some room to grow. For the money, the PTE6152 is a good turbo.
It's the turbo I have, and is the best turbo for my setup.
If your goal is 300hp, the FP Big28 is another option for the same price (if you send FP your T25 as a core exchange, you save $100, and you have to get the install kit for the evo3 b16g which is extra $$$ above the turbo price). The evo3 b16g may creep on you (search for creep, and it's usually an evo3b16g), and the FPB28 shouldn't. The fpb28 is a true bolt-on, too, so you won't have to worry so much about a tech article (your other post).
The e3b16g will give you more growing room than the fpb28, though, but not a huge amount.
