Difference in OEM coolers?
97gst_spyder
2,262
16
Sep 1, 2008
Lakeland, Florida
So I'm swapping an auto trans into my Spyder starting this week. I have two transmission coolers from two different 2g DSM's.
First is a 2g FWD N/T Spyder 97-99 auto. It mounted to the driver's side front corner. It has 2 3/8ths barbs on it.
Second is a 2g AWD Turbo Talon 98 auto. It had a cooler mounted just right of the center support in front of the radiator. It uses large banjos (14mm maybe, with 17-19mm head).
The coolers are the same size just different connections. Is there a reason for this?
Do the turbo transmissions have a much higher fluid pressure to the cooler?
Thanks for any help!
Ok, thanks for the answers! I'm planning on using the barb'ed cooler for the trans and the banjo for the oil with the evo 9 ofh.
Thanks again!
