99gst_racer
Moderator
- 12,009
- 1,696
- Apr 5, 2003
Coloma,
Michigan
What is the difference between the T25 wastegate actuator and the 14B actuator?? Can they work on each other? (ei. T25 actunator on a 14B?)
Thanks -Paul-
Thanks -Paul-
nine5raptor said:No, it will not work. :thumbdown The two actuators mount up completely different. If you really wanted to, you could adapt it to fit, but it is much easier and will be cheaper to just pick up a used actuator.
