Definitive timing belt replacement job parts list?
AWDPetmitsu
1,054
15
Jan 26, 2003
., Pennsylvania
I'm going to change the timing belt on my 1G '91 GSX soon. Is there a definitive list of all the parts REQUIRED AND RECOMMENDED to be changed? So far, I've come up with this:
balance shaft belt
timing belt
timing belt idler pulley
timing belt tensioner pulley
balance belt tensioner
water pump
a/c belt
power steering belt
alternator belt
lower timing belt cover gaskets
crank pulley
oil pump seal
I've searched and found someone recommended the front crankshaft seal and cam seals be replaced, also. Is that true? Am I missing anything else? Please add to the list if I am. Thanks. :)
Yes, yes. That's where I got the list from. I've looked around and found some more items that people replace while they are doing this job. They are:
oil pump seal
front crankshaft seal/front main seal
camshaft seals (2)
front balance shaft oil seal
rear balance shaft o-ring/seal
Anyone have anything else?
