Dead coil, tried 3 different coil packs
onefast2gdsm
866
6
Aug 30, 2010
millersburg, Pennsylvania
So I recently did a wire tuck and cut some wires. I rerouted the wire harness along the firewall so it would be hidden. Power transistor is mounted under intake with a bolt to where the stay bracket would be for the intake.
I have a 6 bolt swap so my coil pack say 4123 but my wires are 2341. I am not getting spark on cylinders 2&3, I've tried 3 different coil packs and 3 different power transistors. Cas worked before the tuck and I even tried moving the power transistor back to the stock location.
The wires I cut were for the solenoids on the firewall, cruise control, and a blue plug that wasn't connected on my car. What does the coil pack tie into that might have got messed with when doing the tuck. I am at a complete loss. And yes I had my battery disconnected while doing this.
If I am not mistaken the blue plug is for the tach check. Did you cut it off , or did you cut off the plug and solder the wires together?
This might be your issue , if you just cut of the plug.
yeah thats the test connector. Connect the 2 wire end together and it should fix your issue.
Basically it ties ignitor(black/white) pin 8 to pin 2 of the coil (blue/red) and you just cut that by cutting the test connector.
That is used for diagnostics , the usually hook up a test tach on it. But its not a connector in the normal sense , think of it as a vampire clip.
Grounds and power wires are shared, so that won't cause your situation. You're missing a signal. You might just have a wire that is broken inside.
Resolved. Soldered the wring blue/red wire. Thought it was the check relay wire but it was for a solenoid. Found the correct blue/red wire and all is well. Thanks everyone for their input!!!
