Dead clutch pedal
RickClarke23
93
Apr 5, 2004
Bishop, Texas
Ok so my problem is this. If i leave the car sitting for a couple of days without driving it the clutch pedal has no pressure and will just stay stuck to the floor when pressed. After I pump it a few times though it regains the pressure and works just fine. What could be some of the causes of this?
Check the fluid level in your clutch fluid reservor, or it may be your clutch slave leaking fluid/pressure. Look around your cluth pedal and see if there is any fluid around the carpet in that area.
Maybee your cluth return spring came undone. Check the cables under the hood that go to the tranny.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
