Day 83: Fail on the Updates
SpawnedX
Banned Member
4,016
57
May 18, 2004
West Warwick, Rhode Island
:coy:
Okay, well I haven't been doing my part in keeping this updated and I am sorry. I have been doing a lot of parts purchasing and collecting. I guess I will start off this entry with what I have and then start adding pictures as I take them.
For this list, items that are not bold, have not been purchased yet. You will see that list has gotten pretty small compared to what I do have.
1999 Mitsubishi Eclipse GSX - Build List
Engine Block Modifications:
  • Stock 1999 7 Bolt Block (Split Thrust Bearing)
  • SBR Balance Shaft Eliminator Kit
  • Fluidampr Harmonic Dampner
  • ARP Crank Pulley Bolts
  • ARP Sprocket Bolt
  • Unorthodox Racing Lightened Pulley Set
    [*]Bonehead Performance Stainless Steel Oil Pan Bolts
    [*]New OEM Oil Pump
    [*]New OEM Water Pump
    [*]New OEM Tensioner
    [*]New OEM Timing Belt
Cylinder Head Modifications:
  • Stock 1999 7 Bolt Head
  • Crinkle Red Valve Cover
  • Top Line Revised Lifers
  • Evp IX OEM Beehive Springs
  • Evo IX OEM Retainers
  • Stock Valves
  • FP2 Camshafts
  • Kiggly HLA Regulator
  • OEM MLS Head Gasket
  • ARP Head Studs
Forced Induction Modifications:
  • FP Race Manifold
  • New OEM Exhaust Studs
  • Genuine MHI 16G - Ported and Flapper Removed
  • New OEM Turbo Bolts (2 DSM & 2 Evo)
  • Punishment Racing Stainless Steel O2 (38mm Flange & Externally Dumped)
  • TiAL 38mm Wastegate (F38)
  • All Copper Gaskets
  • Hallman Pro RX Boost Controller
  • GReddy Type RS BOV
  • Precision Intercooler (Garrett Core) 3.5"
  • Punishment Racing 2.5" Aluminum Intercooler Piping
Intake Modifications:
  • K&N Forced Induction Filter Kit
  • Dejon Tool Intake, Recirculated
  • Magnus Motorsports SMIM
  • Ported 2G Throttle Body
  • Custom Made Cold Air Box
Exhaust Modifications:
  • Punishment Racing 3" Downpipe (Cat Deleted)
  • Thermal R&D 3" Exhaust
Suspension Setup:
  • Tokico Illumina (White) 5-Way Adjustable Shocks
  • Eibach Pro-Kit Springs
  • Konig Zero (18x8) Rims
  • Nitto (235/45/18) NT05 Tires
  • Gorilla Lug Nuts, Chrome
  • Powerslot Brake Rotors
  • Hawk Brake Pads
  • Goodridge Stainless Steel Brake Lines
  • RRE Rear Camber Kit
  • RM Sway Bars
  • OBX Lower Tie Bars
  • Megan Racing Front Upper Strut Bar
  • Megan Racing Rear Upper Strut Bar
Driveline Modifications:
  • New OEM Clutch Master Cylinder
  • New OEM Clutch Slave Cylinder
  • Extended Slave Rod
  • STM Master to Slave Stainless Steel Clutch Line
  • ACT 2600 Pressure Plate
  • ACT 2600 Street Clutch Disk
  • ACT Streetlite Flywheel
  • ARP Flywheel Bolts
  • New OEM Pressure Plate Bolts
  • Shep Stage III Racing Transmission
  • New OEM Throwout Bearing
  • New OEM Clutch Fork
  • New OEM Pivot Ball
  • New OEM Fork Clip
Fuel Setup:
  • FIC 1150CC Injectors
  • STM Tank to Rail Fuel Kit w/ Fuel Lab Filter
  • STM Fuel Return Kit w/ Fuel Lab AFPR
  • Rewired Walbro 255LPH HP Fuel Pump
  • Magnus Fuel Rail
Ignition Modifications:
  • NGK Premium Ignition Wires
  • NGK BPR7ES Spark Plugs
  • Dynatek ARC-II Ignition Amplifier
Engine Management:
  • ECM Link version 3.0 (EPROM)
  • Innovate LC-1 Red DB Wideband O2
  • GlowShift Red Digital Boost Gauge
  • GlowShift Red Digital Oil Pressure Gauge
  • GlowShift Red Digital Water Temperature Gauge
  • GlowShift Black A Pillar Triple Gauge Pod
Cooling System:
  • Mishimoto Aluminum Radiator
  • Mishimotor Slim Fans
  • 165° Thermostat
  • Mishimoto Radiator Hoses
Miscellaneous Modifications:
  • 2G Non-Cruise Control Cable
  • B&M Short Shifter
  • Symborski Shifter Kit
  • OEM "Heavy" Leather Shift Knob
  • STM Ball Bearing Shifter Cable Inserts
  • Shep Shifter Cable Bracket Spacers
  • RRE Oil Catch Can (x2)
  • Erbified Motorsports Aluminum Overflow
  • GReddy Turbo Timer
