datalogging
1998gstspyder
246
3
Jun 10, 2004
Glendale, California
In order to datalog, you would need any PDA, and a cable to hook it up? What does it hook up too? SOme guy is selling a Sony Clie PEG-320 "indiglow" palm...after i get the Palm and cable, do I need anything else to datalog? for example software? if so where do i get it from and is it cheap? sorry got lots of questions, but thanks.
btw its sellin for 25, do u guys recommend it?
To datalog with a pda you will need a cable to connect it to your diagnostic port and the software to run. I personally have the pocket logger software which can be found at www.pocketlogger.com and probably runs around $140.
As far as which pda to use I would reccomend something simple such as the m-100 by palm. You should be able to pick one of these up for as little as $10
Hope that helps you
well on that same site u will find a list of compatible palms
U can also buy a 10-20$ ebay cable and they usually provide the software too
Last thing u will need is a hotsync cable to connect the pda to the ebay cable
Good luck and read a lot
The hotsync cable lets you transfer information back and forth to the palm, such as uploading the software onto the palm, or uploading logs to your pc. 1g's have it easy, we have MMCD. :D
