datalog
theycallmebruce
154
Dec 5, 2003
Flushing, New York
i recently switched to a blow-through 3" GM MAF. RPM signal tapped into the blue/red wire off the CAS. i've got the BASE knob set at 1 tick rich, which was a suggestion from a document on the dsmtranslator Yahoo group. Everything else is at 0 and i have not turned off fuel cut.
here's a log taken tonight. i've only put in the points where the timing or O2 reading changed. this was done on an A/T with OD off (3rd gear):
RPM Timing O2
3092 8 .98
3244 9
3268 8
3288 7
3264 8
3268 7
3356 8
3484 9
3720 10
3952 11
4172 13
4324 14
4428 15
4536 14
4576 16 .96
i also did a run while maintaining 60 for about a minute and timing was close to or near 30 all the time. RPMS were at around 3500 and O2s were like all over the map.
1-can i get some help making heads or tails of this? is this where i should be?
2-how can u tell if it's running in open or closed loop mode (if WOT modes are active?)
thanks
at wot its closed loop.
stock turbo ? if so the timming looks a tad low and o2 a hair high.
ya could lean out a bit.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
