datalog cable
mysticj
325
30
Apr 12, 2007
charlotte, North Carolina
Will this cable scheme work with a Palm OS(palm emulator)
or make one like this one?
Will be using a serial-to-USB adapter. Will it matters?
In other words, the first diagram should work on the PC with a serial-to-USB adapter using Palm OS.
Thats the scheme I used for my IIIc palm,but It could be different for a laptop.
Steve, is there a way to tap my serial cable for my palm, to charge the palm? All I have is a usb charger that came with it. If so which pin on the serial?.
Mystic, G/L
While the diagrams look the same if you don't look closely, the Palm version changes the two pins or transmit and receive and uses a different sex connector. The passive one above is for a PC serial port. I did not check the active schematic to figure out which device it was for.
Don't know.
So the question is: Which cable will have a faster sampling rate?
