cyclone IM and cams
Definently a good idea. I'm about to have the same setup on a e85 e316g. I think it'll have the same if not more lowend torque than a stock cam setup but with alot more topend.
The benefit of the cyclone is the low end. I dont think you will lose much. Top end you will enjoy.
Despite the fact the cyclone offers dual runners, you will still give up low end torque, but its only about 5% until boost threshold.
Interesting...The 272 does intead to reduce torque in the lower powerband but with a cyclone and 2.4L, the torque should not be affected. BTW, FP3 and oem Evo 8 beehive springs? Good or use of aftermarket springs?
I'm having a hard time understand what you're trying to communicate. The 2.4 will definetely offer loads more low end torque than the 2.0, but compairing the stock manifold on a 2.4 versus the Cyclone manifold 2.4 you will still lose low end torque. It will be negligible but true never the less.
If any negligible amount of torque loss on a 2.4 with the Cyclone IM & 272* intake cam.
  • Wanted 6 bolt NT water pipe
    • chrisman287
