2G Crankwalk/Fluidamper
2GRick
86
Nov 13, 2009
Norcal, California
Hi to all....Hopefully someone has accurate info on this issue. Is there any indication that useing a Fluidamper balancer helps eliminate CW. Please be specific and not just "well my buddy says". Thanks in advance
Crankwalk is associated with poor bearing design on the earlier 7 bolt. It was later on "fixed" in some of the 98-99 blocks with the split thrust bearing. Usually the only thing that does not help is the billet aluminum underdrive pulley which used with the 4g63 throws off the harmonics and balance of the engine and can sometimes lead to "crankwalk".
