crank turning
killab443
602
3
Nov 24, 2003
Howell, New Jersey
what happens if you turn the crank a bunch of times counterclockwise, can it mess up the lifters?
killab443 said:
is that the only thing that can happen?
umm well that's a REALLY bad thing to have happen, because the next time you start the engine could be the last.....valves meeting pistons :thumbdown
Did you do this? If so redo the timing belt before you start it again, or at least check the timing is lined up and shit.
  • Wanted 6 bolt NT water pipe
    • chrisman287
