twicks69
Supporting Vendor
- 4,315
- 2,037
- Mar 12, 2004
Milwaukee,
Wisconsin
I have brand new in box set of CP SC7263 pistons available; they are with 0.155" wall 22mm pins with oversize valve reliefs, no coatings.
4G64 block with 4G63 head
0.040"-over, 87.5mm
100mm stroke
156mm rod length
9.5:1 compression
Wire locks
CP piston rings supplied.
297g ~piston weight
Asking $525.00 shipped in USA! or $500 + international Fedex shipping for out of country.
These retail at $689.00 + shipping.
These pistons are normally used in 6-bolt or 7-bolt DSM/Evo/Kia/Hyundai 4G64 blocks with 4G63 cylinder heads. This specific set was produced for Andrew Brilliant's time attack car as a backup set and was not the right bore size.
They have not been removed from plastic and are new in box.
CP website info:
SPORT COMPACT PISTONS -
Brand = Mitsubishi -
Part Number = SC7263
Bore (in) = 3.445
Bore (mm) = 87.5
Size = +1.0mm
Stroke = 100
Rod = 156
Comp = 1.134
CR = 9.5
Pin (mm) = 22
Ring Thickness = 1.0 x 1.2 x 2.8mm
STANDARD FEATURES INCLUDE:
Deep valve relief depth accommodates high lift camshaft
Made for +1mm valve sizes
Custom skirt cam and barrel design
Accumulator grooves
High strength aluminum forgings
High performance rings
Fully CNC machined and balanced to +/- 1 gram
Wrist pins included at no additional cost
Double pin oilers, force fed oil ring
Pick lock grooves for easy lock removal
Pin fitting included
I ship FedEx Ground Insured as preferred method domestically, and Fedex International Express for international shipping.
Email me at [email protected], or PM me here.
Thanks,
Tim Zimmer
TMZ Performance
0.040"-over, 87.5mm
100mm stroke
156mm rod length
9.5:1 compression
Wire locks
297g ~piston weight
CP website info:
Bore (in) = 3.445
Bore (mm) = 87.5
Size = +1.0mm
Stroke = 100
Rod = 156
Comp = 1.134
CR = 9.5
Pin (mm) = 22
Accumulator grooves
Thanks,
Tim Zimmer
TMZ Performance
