Could it be brakes?
mic84
40
Mar 3, 2005
Fresno, California
hey ppl,
I have a problem and i need help. Whenever i drive,i can hear a metal-metal touching sound coming from my wheels..as soon as i hit the brakes,it goes away. This only happens sometimes. any idea what is wrong?
any help appreciated.:thumb:
that could be the brakes, but it could be alot of other things too.
Your best bet would be to get the car on jacks ASAP to shake down the suspension and check everything out.
I had the same problem after I did my tranny turns out I just bent the dust sheild on it ever so slightly and it started to rub the rotor so that is something to check but definatly dont fool around and put it off if there is any chance it could be your breaks.
Good luck,
Brandon
There are a few tests you can do.
RPM Related
While the car is running and completely stopped, rev the motor a little bit and see if the sound speeds up or gets louder.
Speed Related
Can you hear the noise when cruising at a set speed? Then if you accelerate, does the noise speed up or get louder?
Boost Related
Does the noise start as you enter boost? Does it get louder as the boost increases?
Drivetrain Related
While driving, if you put it in neutral or even turn the car off, does the noise continue as you are coasting?
thanks for the replies..i'll probably get it checked out. i think it is the brakes..nothing gotta do with the RPM,speed,etc.
Your pads are shot, put in a new set. Clean and lube the pins while you're there, and get the dust off everything. Chamfer the edges of the pads and use Brake Quiet if you care about squeaking.
