COP + DIS-2 wiring diagram?
If you can tell me the instructions for the msd dis II I can get it wired up properly for you, I work on ignition systems all day for a living. PM me if you have a diagram for the DIS II and I will get you on the right track.
For starters the dsm ignition system uses a waste spark distributorless ignition system. It has one wire with a positive current(red). The other two are grounds activated by drivers in the ecu. When you go with a coil on plug you need the Positive wire to be hooked up to coils 1 and 2, then you run the - side of coil 1 to the + of coil 4, then hook the - from number four up to the 1 and 4 driver wire to the pcm. Then you run the - of coil 2 to the + of coil 3, and the - of coil three hooks up to the gound/driver wire for coil 2/3.
Hope this helps, if you need more pm me and I will jump back on.
I already have the COP installed and working, just looking for a diagram to install the dis-2 to the 3 wires for the COP. Can we eliminate waste spark with a dis-2?
