Coolant Temp sensors.
Kevin TSI
136
Jan 11, 2007
Muncy, Pennsylvania
:confused: Can I get away with only having the tmep sensor in my thermostat housing? Will my temp gauge still read the same? I have an aftermarket aluminum radiator so I have no spot to screw in the temp sensor for the radiator.
Anyone know? I want tp put it back together.
The one in your radiator is actually your fan switch. Go toggle switch and relay on some slim lines.
Sweet. Thanks a lot. I have the fan on the toggle switch already and was pissed because I wasn't getting a temp. reading but then I found out that the wire was off the one on the thermostat housing.
