Coolant Leak
Frankie
Dec 13, 2004
So Cal, California
I was wondering if anyone else has had the same problems as I have. I bought the car (a ’98 GS-T Spyder) in April. In May I started having problems with a coolant leak and the car started overheating. We figured out that there was a problem with the thermostat and changed it. Everything was good for about 2 weeks and then it started leaking again. It took a while to start overheating, about 1 ½ months. Took it to the shop and they said it was the clamps. And $150.00 later all of the clamps were changed and things were great for about 2 weeks. It is now starting to overheat again and I don’t know what the problem is. Any help out there?
Does this mean it's still leaking?? :confused: If so you need to find the source of the leak and fix it so you don't run low on coolant ...
Yeah. I was wondering if maybe these cars had this problem often and if someone had any advice as to what it was. I can't find exactly where it's leaking from.
