Comp 101300 too small for 2.4L and FP3052
I would run bigger cams than those. IMO a set of HKS 272's would be perfect for the rpm range of a 2.4. A lot of the newer 272 cams really push the rpm range higher than I would want it to be on a 2.4. This of course all is assuming you are building a street car.
I have 264's in my 2.4 and the power falls off pretty fast after 6k but this is also on a 16g turbo. I does make for a killer street setup will amazing torque and instant boost. I do however plan on stepping up to a 272 cam when this winter for the HX35.
The motor will breathe better up top. You have a 2.4L motor and a ~52lb/min turbo.
Let her eat.
I would consider the GSC S2's, Kelford 272s, or similar. Adjustable gears would be a good investment as well.
  • Wanted 6 bolt NT water pipe
    • chrisman287
