Comp 101300 Cams 2.3
nastyleak
93
Oct 14, 2010
Mobile, Alabama
The information given by most vendors says these are ideal for a stroker with the stock turbo. Does anyone really spend the money to build a stroker and use the stock T-25? I seriously doubt it! Would these cams work well with a 68HTA 2.3? Is it really likely that these would cause the guides to wear prematurely?
Trying to decide between Comp 101200's and 101300's.
cams for this platform change the power curves more then changing the peak numbers. i cant give you a specific answer but search around for which one has the engine characteristics you want. RPM, peak, torque, etc.
i am going 10:1 stroker, with the stock cams, and a evo 3 16g. usable power range is gunna be something like 2000rpm to 6000rpm. at that point shift gears, i have no desire to spin 9000rpm.
