Colorado Springs/Castle Rock/Pueblo Meet June 1st!!!
I have a '97 Spyder so those wouldn't work. And further wouldn't work with the 6 bolt. I probably should have posted in the Denver/Springs section for a new CAS first before buying the one I did from the other member.
But if those some how can work on my setup, that'd be new to me.
As long as you have a 2g head the 95/96 CAS will work. You just need the cam gear to go along with it and then swap the firing order. Maybe extend the wiring too. So it'd be a lot of work, but definitely possible.
Hope to see you guys up there!
How would that work for the crank sensor? I see what you're saying for the cam sensor, but not the crank.
Ah, blonde moment. If you don't have a separate crank sensor then the 95/96 CAS wouldn't work.
That was my confusion when you first mentioned it. There's no provision on the front case for it since it's a 6-bolt (I'm sure you already know). Don't feel bad, I have moments like that all the time. ALL the time.... ;)
See everyone at 10am. For the guys meeting us in Castle rock we will be at the Outlets around 12. You can text me if you cant find us when you get there 303-506-5135.
BTW guys, I'll be bringing a few T-Shirts for your purchasing pleasure. I have Medium and Large- $10 each. So bring some cash if you would like one!
Just wanted to say I had a good time yesterday despite the light turnout. But the company of a good few is always better than a bad crowd. I'll post up some of the pics when I get a chance.
Also, big thanks again to Tony for organizing!
Yea thanks for coming out! I think we should try to do a build day next time! Instead of rolling out somewhere we can all bring the parts we have been neglecting to install, fix, or whatever. With more people working on cars becomes an event instead of a chore LOL
It just makes sense that when you put three or four different dsm'ers together they have probably experience most issues and know how to fix crap!
A shop day would be cool. If you guys don't mind the drive to Black Forest, we could definitely use my hole in the wall.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
