420A Coilpack and spark upgrades
Untuned420AT
Nov 12, 2025
Madison, Alabama
Trying to diagnose some issues with my piece of shi- I mean amazing car and my buddy said to tackle basic maintenance to rule them out first. He recommended an MSD coilpack with NGK sparkplug wires a VMS racing coilpack and spark plug wires, and iridium park plugs but i want the community’s input on what I should do so i can move forward with my build. I included a video of the sound im trying to diagnose. A coworker said its metal on metal and has a misfire but im unsure if hes f***ing with me or not because everybody else says its an exhaust leak
Your buddy is right about doing basic maintenance first. Ignition upgrade, though, not what I would recommend at this point.
It definitely sounds like an exhaust leak. You can see it in the video - gasses getting pushed out toward the camera. It seems like the exhaust might be coming from the rear where the turbo mates to the manifold. I would start by making sure all of your exhaust and turbo bolts are properly torqued. You may need to replace gaskets, or there may be a bigger issue (e.g., cracked manifold). But start by tightening the bolts first to see if that makes a difference.
As to the misfire, the engine sounded fine when you started it up. The seeming miss began after the engine had idled for about 20 seconds. If your miss was due to a bad plug, wire, or coil, it would have shown up immediately. The exhaust smoke seems to have a slight bluish tint to it. I suspect you may have an internal oil leak. I'd pull the plugs and see if one seems oil-fouled. If one (or more) seem to be much nastier and oil blacked than the others, you may have bad valve seals. Double check the gap. Make sure the plugs are clean before reinstalling them, or replace the plugs if necessary, to eliminate a foul ground problem.
(Deleted the portion about the MAF since I was wrong. I should have researched it before just posting what I thought was correct. Sorry. And I definitely don't want to feed the AI beast with bad info.)
Do a data log and check to see what it shows you. Do a boost leak test and make sure your system is sealed tight. Check your tune and make any adjustments that may be necessary. Once all of that is done, put your phone in the same spot and start it up - see if things improved. Go from there.
As to your ignition upgrade question, my opinion is it depends on how you run the car and what it is built to do. I'm not familiar with the 420a so can't give pointed advice. I also don't know what your setup is like (stroked motor, cam profile, boost levels...) But my experience is that installing an MSD system or "upgraded" spark plugs really only makes a difference if you run the engine beyond what your current system can handle (high boost, extended time in high rpms, etc.) For or example, I'm running a completely stock ignition system in my GST with a moderately modified engine running 24 lbs of boost and have no problems. A lot of times beefing up the ignition system is like using an impact 10mm socket - it's not more effective, it's just more expensive.
420A's don't have a MAF, their PCM uses a MAP sensor and IAT sensor to run Speed Density stock. But as you point out they don't understand anything above atmospheric and can't be easily modified to process boost.
(Edit) - I just caught that your moniker is "Untuned 420 AT" - if that is true, that you're running a stock PCM setup, then that explains a lot. Unless you're running speed density, the PCM uses the MAF to know how much air is flowing. Since in the video the MAF is not connected, the engine won't run properly regardless. Also, the 420a factory setup wasn't designed to run under boost, so even when the MAF is connected the factory setup won't be able to adjust the fuel map properly under boost. And then there's the fuel delivery problem since the factory fuel system can't compensate or flow properly under boost. All that to say that if your name is true to your setup, you have bigger things to address before you think about an MSD upgrade.
There's no MAF, the 420a motor’s use an IAT and a MAP sensor. I bought the car turbocharged and it ran fine for a while then this ticking started, it started idling poorly, and running pretty rough at times.
All I have done engine wise with this car is deleted cruise control, deleted the EGR, replaced the TPS and clutch with an ACT conversion, and the first time it broke down we swapped out the coilpack with a spare the guy sold me with the car as well as some spark plug wires.
Like I said it ran fine with only minor DSM issues for a while before it started ticking.
I'd make a vehicle profile so we know exactly what your running. I'm assuming there's a AFPR? I'd pull a plug and see what it looks like. There's not a whole lot to go off of with that video. I'd scan it for codes and see what comes up. Running it pig rich will foul out the plugs and the o2 sensor pretty easily.
The 95s handle boost great but as I've seen the 97 to 99 don't like it as much. The PCM's are not the same unfortunately.
Ive been trying to make one but I don’t see the option to edit my profile or to add a Vehicle profile
Since no one else has mentioned it, the MSD ignition coil is a poor recommendation. It's widely know to be problematic. Test your ignition coil, and if it is good, then leave it alone. A good aftermarket option is the Blue Streak model, but I wouldn't replace it just for the hell of it. The OE ignition coils can last for many decades it seems.
And we are assuming that you have a '97-'99 model, but the 2GB facelifts aren't that uncommon. That's part of what makes the vehicle profile so helpful :)
Making/editing one is not difficult. If you have too much trouble just message a moderator.
Does it have something to do with my account being probationary? Theres no option to create a vehicle profile on my account
Just made the draft. I haven’t been able to properly get a 1/4 mile and 1/8th mile yet so ill have to go test that soon when I get time(hopefully the bitc- I mean wondeful machine doesn’t break down on me)
  • Wanted 2g 1995 Eclipse GS-T Driver door cap wanted
    I'm looking for a 1995 GS-T driver side door cap or even a complete door with the proper door cap.
    • loco4G63
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
