jarero
- 30
- 0
- May 18, 2005
Pullman,
Washington
For about the past month my car (96 TSI AWD 5spd 84k) has been hesitating under boost intermitantly, a few days ago I got a check engine light (P1105, Fuel pressure solenoid) and this morning on my way to work a new problem developed. The car started and ran fine including a long warmup to defrost everything then when I got into traffic and at full temp I had to stop due to traffic and as soon as I pushed the clutch in the engine died. I started it back up and had to keep my foot on the gas to keep it running. When you are moving and in gear the car drives fine. From a search that I did about the fuel pressure solenoid it sounds like it is an unecessary part and that it could be removed from the car? If this is true could this be causing my low idle (400rpm) condition and stalling problem?
My car is stock except for the following:
9lb flywheel
ACT 2600
Dejon upper IC pipe with non-recirc BOV - I bought a recirculating BOV to replace the POS that came on the car when I bought it but haven't had a spare second to put it on.
Any help would be appreciated!
9lb flywheel
ACT 2600
