Clutch/Trans troubles o_O
chelc724
Aug 5, 2012
Loreauville, Louisiana
ok, i have a 98 eclipse rs, and something really weird going on with it. was having issues with the clutch, so i changed the master cylinder, slave cylinder, and eventually the clutch. this is where it gets weird. i can put it into gears, but the clutch pedal has no pressure! so i can't figure out what's up. my hubby and i have bled the system til we were blue in the face and it hasn't done anything. i can't understand why it's going into gear but the clutch isn't holding. can anyone help with this, ### we really need this problem fixed.:idontknow:
You can put it into gears while it's running ? Or no. Also, was the clutch installed correctly?
  • Wanted 6 bolt NT water pipe
    • chrisman287
