2gspider
- 0
- Mar 22, 2007
omaha,
Nebraska
Hi all DSM lovers,
I'm a total newbie so please bear with me. I got a 98 Gs spyder a year ago, didn't drive it much until this spring. Today i start check fluids in the engine bay, i see the clutch reservoir is empty. What kind symptoms should i had experienced when the reservoir is this much empty?
Obviously, i need to refill it
. Please look at the attach image, Can you tell what is the black googie stuffs, are those supposed to be in there? Should I wipe them off first before refill. Also is there any clutch fluid or type recommend?
Thanks a lot!
. Please look at the attach image, Can you tell what is the black googie stuffs, are those supposed to be in there? Should I wipe them off first before refill. Also is there any clutch fluid or type recommend?Thanks a lot!
Ok, i think it really leaked. Do i just replace that black thingy or entire assembly? Sorry for lack technique terms.
