Clutch pedal acting weird
GSEclipse620
128
Nov 29, 2005
Monmouth, Maine
My clutch pedal has been acting weird latley. It is a thing that comes and goes. Usually it only does this when I've been driving it harder, but not always. I had to jump my car from a roll today and it did this on the way home. The clutch will engage much higher, and the pedal will have a farther travel. It will still engage all the way and won't slip it's just the pedal that is acting weird.
I'm assuming I just have to tighten something on the pedal assembly but I'm not sure where to look. Advice or thoughts on the matter apprieciated, Thanks.
Try bleeding it and checking the slave cylinder. Sounds like a faulty cylinder or air in the line.
I've had to do that before. But I didn't thought this might be in just the pedal assembly itself because the clutch is still grabbing stong and is not slipping. I just went out to get a new battery and half way through the ride back it started acting normal again.
