1G Clutch not disengaging
91lzer
74
21
Aug 22, 2022
Penticton, BC, Canada
I replaced my clutch about a month ago and drove it for 2 weeks without issue. But my master cylinder blew and the clutch would hardly disengage. So I replaced the master and the slave cylinder but now the clutch won’t disengage whatsoever. I’ve bled the clutch for hours using different methods and it still just won’t work. I’ve also tried adjusting the pedal but it’s all the way out. I’ve been told that i could have a bent release fork but I’m not sure that’s the issue because I was driving with no problems and when I did have a problem, I could see fluid leaking out of my master. Any advice?
There is also pressure on the pedal and the slave moves just over a centimetre when the pedal is pushed in. The clutch installed is an OEM excedy and the flywheel was machined
  • Wanted 6 bolt NT water pipe
    • chrisman287
