Clutch ISSUE Please help (Slave Cylinder).
jbark
115
May 11, 2008
Reading, Pennsylvania
so i had an awesome surprise when i left school yesterday. my clutch would not disengauge and the petal was on the floor. so AAA sent a tow out and the gut replenished my fluid and got it to drive so i got home fine but i could see my slave cylinder was leakingso i get down to play with it and change it and the plunger was a lil loose and wiggled. so i moved it more and what looks to be a 10mm bolt falls out of where the end of the blunger is. the bolt was broken and looks to be the piece that the plunger pushes on since it has an groove on it. so i was wondering what this bolt is and if i can fix it or if i need someone else to. lmk jeremy.
Well if Im understanding correctly, then it sounds like one of the bolts that hold the slave cylinder in place came loose and broke somehow. If this is a correct assumption, then find another bolt to thread in and tighten the slave cylinder down, fill up the reservoir with fluid, and bleed it then see where you are at.
