clutch dragging
blaze12
127
Nov 27, 2010
St.Charles, Missouri
Hi there ,today i was working on my hub so i had my car jacked up and then my friend wanted to hear my motor without the muffler, so i took it off and started my car in neutral and the wheel with the hub i was replacing was spinning and the car was in neutral, but then i stick the clutch in and it stopped spinning so confused?
Wouldn't worry about that, as it's normal.
Easy way to check if the clutch is dragging is to push the clutch, set it in first gear (continue holding the clutch down obviously), rev the car to a high RPM. If the car starts moving while the clutch pedal is all the way down, you have a dragging clutch.
