clunk/clank from driveshaft?
tarheels23
101
May 15, 2011
struthers, Ohio
When I am sitting still and put it into first and start to move, there's a little clank from the drive shaft. There's a little bit of side to side play in my carrier bearing closest to the front end. Any tips or things I can check?
there are a few things to check, I would start by checking the drive shaft carrier bushings, the carrier it self, the U joint and then the allowable radial play of the driveshaft.
