Resolved Checking Relays?
805eclipse
159
Jul 16, 2003
Newbury Park, California
I was wondering how to check if the relays in my car are good or bad?? my door locks, radio, and interior lights just went out so i want to check them. Thanks
Solution
If it's a SPDT relay, for example, you'll have something like below:
For this relay, you have a N/C (normally closed) post, a N/O (normally open) post, a common post and two coil posts. You'll need a multimeter with a resistance (ohms) option and/or a continuity option.
You would first test the N/C (normally closed) pole's continuity by checking resistance between the N/C pole (87a) and the common pole (30). There should be little to no resistance between these poles. Then, you'd check the resistance between the common pole (30) and the N/O pole (87). There should be no continuity (infinite resistance).
Next, you would apply 12V between the coil poles (85 and 86). Then...
we were just talkin about this in my shop class the other day, and my shop teacher pretty much said its a pain in the ass, he said somethin like u have to hook them up with little jumper cable things to your battery and use a test light or a d.m.o.v., if im wrong im sorry i dont know a whole lot about relays. he said the DMOV is alot easier, but im guessin u probably dont have 1. there like 60 bucks. and is like a test light but alot better.
Next, you would apply 12V between the coil poles (85 and 86). Then, you would recheck resistance between 87a and 30 - there should be infinite (or very high) resistance (no continuity). Then, you would check resistance between the N/O pole (87) and common pole (30) - there should now be continuity (low resistance).
Basically, it's all about understand how the relay works: you apply a voltage to the coil, the coil energizes and closes a switch. A closed circuit should have continuity - an open circuit should not.
Solution
Your shop teacher had better stick to teaching.
Grab a known good one and substitute it into the suspect circuit. If it fixes the circuit, the relay was bad. Or, vice-versa, put the suspected relay into a known-good circuit. If the circuit no longer works, the relay's toasted.
Shop teachers. :rolleyes:
