TwoLiterV8Eater
- 330
- 1
- Sep 2, 2002
Gainesville,
Florida
They dont have a .50 trim turbo because a .50 trim is not an off the shelf garrett turbo.
Originally posted by Slowboy
If you are buying an "off the shelf" Garrett turbo without a 360 thrust bearing... and want to run high boost have fun.
Why do you think the Honda guys do NOT have problems with these turbos? Oh, thats right, they run like 8 psi.
Run 20 plus PSI for about a week on a $549.00 turbo... and then see how well you like it!![]()
am just asking becasue I do not build turbos. But what if you can get a a turbo with that 360 thrust bearing. Would it then be acceptable?
It just doesn't make sense! I these turbos are Garrett direct turbos then what is the difference?
I know when you make hybrids there is machining and balancing involve but that is irrelevent here
I know what answer to expect from most of the vendors out there. Because they need to justify the HUGE mark-up in their PROFITS
That sucks you must be pulling my leg dude! I mean you must just like to have a warehouse of these to stare at. Let's make a deal you give me some wholesale turbo's and I'll show you how to make 40-50% on tires. 12%
I happen to like when profits are 10-12% on turbos. Go ask your boss if your company would survive on that profit margin... See what he says! Then post his answer here, just leave out the explatives.
[/B]
10-12% on turbos? MY A$$!!!! Be honest
I can understand you're trying to protect people from buying the wrong turbo but you don't need to flip out just because you got someone out there selling turbos cheaper than you.
. I can sell the same junk he has at the same prices. I would not do it however, since it is not going to work for long.......... Does not seem like good business.Let's make a deal you give me some wholesale turbo's
Just Relax Slowboy...........
tdo6 turbine wheel $85.00
will you then believe MR. Huml ?
Guys, the bad thing is... They could spend $300 more and get the real deal ( to4e 60 trim, $795-850 with 360 thrust )....
But we will charge them $300.00 plus parts to rebuild it once they learn there lesson.
So, which one will be cheaper now?
Regards
Mike Huml
For someone that runs a business you sure have alot of spare time to sit in front of your computer and give smart-a$$ replies....
But Garrett makes very few "off the shelf" turbos with the proper 360 thrust bearing.
i would like for you to send me some proof as to why these garrett(honeywell/allied signal) turbochargers will not last long.. please. as these are the same center sections used by precision turbo, and turbonetics to name just 2 of the many that use garrett chra's with their own housings
and as far as honda guys doing only 8lbs on these, i have a guy in california running our t3/to4e .63 a/r stg 3 turbine wheel/60 trim on 1.5 bar putting 415whp.(been running that for about 8 months with no problems.)
So Harry uses them, and Turbonetics use them, but they are both over $200.00 more than yours. Why is this? Do they not add anything? Do they not install a 360 thrust and re-balance?
So, there is a guy running a non 360 thrust at 1.5 bar. I think this is the exception, not the rule ? Years ago, I sold a few like yours without the 360 thrust, except we machined the 5 bolt ford t3 housing for the CHRA. All failed within one month of running 20 plus PSI.
I have never put your business down here, so make sure you read carefully before you post anything stating that I did. I just said that your turbos have there place, but not on DSM's that want to run 20 plus PSI..... I have no beef with you at all...
So, how do you take the turbo apart, install a $60 thrust bearing, balance it, reassemble for $75.00 ?
most of the garrett turbochargers come from the factory with the 270degree thrust, we offer them as they come from the factory and the with 360degree thrust option. as far as the 360 degree thrust option goes, we recommend that it will help disburse the thrust load on the entire shaft and should be used on anything over 23-25lbs of boost.That is great...
But my question is: why would you even offer 270 deg. thrust bearing for high boost application in the first place?
Leon
RR
Regards
Mike Huml
