cheaper short shifter
dsm96rs
269
Oct 11, 2010
Glendale, Arizona
ok so i seen it here and there but how many people have actually just had a shop cut and weld their shifter. i mostly just need it about 2-3 inches shorter. tired of punching my stereo when shifting ROFL. but thats really it right. just have shop cut and reweld. how does this trully effect the throw of it. read around but they all are confusing me. so yeah. thanks
What you have to understand is that a good short shifter also changes the pivot point if the shifter. But cutting and re-welding will work too
cutting it in half only drops the height of the shifter. youll still have the same throw as before. if your looking for a shorter throw your gonna have to get the actual short throw shifter. if not, then cut that SOB! :thumb:
Just pull your shifter out, cut out how much you want to lose from it, and just take the threaded portion and the lower portion to a shop and they should be willing to weld it together for a couple bucks.
Super cheap!!!
And yeah, cutting it down will not affect the throw, you are just making it shorter.
How in the world would cutting it reduce the throw? The only thing that would change is the height. Go ahead an do it
+1 on there being no real advantage to this. Just wait til you can afford a B&M. They come up used for like $60 a lot and you'll know it's done right and not just cosmetic.
Edit: I must admit I sawzalled my old MX-3's and used an autozone knob when I was younger. LOL
I did this on my old car. It worked pretty well. I actually didn't weld it. I did it the ghetto way and just cut it and used the set screws on an aftermarket shifter to hold it on. It acutally held well too.
well the shifter i have now does not have thread anymore on it. but i found a shift knob off a 90 integra that fit right on nicely. so i will do it write atleast and weld it
do you have pics of your shifter?! would love to see it
Yea, The third picture is the 1g and 2g next to each other.
<center>
<a href="http://s527.photobucket.com/albums/cc357/sabremike21/?action=view&amp;current=2010-12-14203642.jpg" target="_blank"><img src="http://i527.photobucket.com/albums/cc357/sabremike21/2010-12-14203642.jpg" border="0" alt="Photobucket"></a><br/><br/>
<a href="http://s527.photobucket.com/albums/cc357/sabremike21/?action=view&amp;current=2010-12-14203700.jpg" target="_blank"><img src="http://i527.photobucket.com/albums/cc357/sabremike21/2010-12-14203700.jpg" border="0" alt="Photobucket"></a><br/><br/>
<a href="http://s527.photobucket.com/albums/cc357/sabremike21/?action=view&amp;current=2010-12-14203745.jpg" target="_blank"><img src="http://i527.photobucket.com/albums/cc357/sabremike21/2010-12-14203745.jpg" border="0" alt="Photobucket"></a>
<br/><br/>
</center>
