Cheap upgrade thats overlooked alot
my96_eclipsegs
Feb 19, 2011
Wisconsin Dells, Wisconsin
I have noticed that alot of people overlook a simple upgrade that is fairly cheap for there car. Its keeping your voltage stabilized. I have found a cheap voltage stabilizer on ebay. Yes I know alot of people don't like ebay but I buy parts from their and haven't had a problem yet. It's called a hyper voltage stabilizer and its made by c-west, it cost me about 20 bucks but there are better ones that cost more. It just bolts to the battery and I have one on my car and I noticed my lights are brighter and most of all my throttle response is right there when I hit the gas. No hesitation no spilt second delay I hit the gas and she goes right then. I don't know about hooking two together only have one because I recently installed a big audio system so when the bass hit the lights dim a very little. I will have to check into it and post when I find out.
From the ad:
-100% Brand New and never been used
-NEW Japan Racing Charging System.
-Exactly same as picture (includes accessories for installation as shown).
-Benefits:
** Increase Torque ** Increase Fuel Economy ** Car Response Up
** Stable Idling ** Quick Engine Start ** Lesser Engine Noise
** Optimize Electrical Equipment performance .
-To improve engine performance. Car's CPU is highly dependent on all sensors that provide data and signals to coordinate different parts in different places. CPU can give best judgment if the signal is accurate which affected by electricity flow in the system. Hence a stable and powerful electrical system in car will ensure best torque and response.
-Installation of the Stabilizer is very simple.
Racing Charging System store electrical energy at all time to provide stable and sufficient electrical energy whenever there is a voltage drop across the supply when power needed from all parts in the car
is there any downfalls on the racing charging system? is it possible to burn up wires or even cause a fire if something isnt right or unstable?
Voltage stabilizer are just a capacitor and no, ground wires do not do the same job.
Also I'd like to say throttle response is directly related to electronics, a physical cable is simple.
jacobevan611;bt12409 said:
Our throttle response has nothing to with any thing electronic. Our cars are not drive by wire. They run off a bike cable.
Yes your right but correct me if I'm wrong the tps, map, ats Have to deal with the way your car idles and accelerates.? And your computer tells the car when floor the car it needs more gas? So by keeping the voltage stabile definetly when you have big sound systems isn't going to matter in its performance???? If not how?
Usatuff;bt12415 said:
From the ad:
-Benefits:
Thank you
