CEL won't stay off
Disturbance
152
Oct 26, 2011
Tucson, Arizona
I have link V3 and recently put the S90 throttle body on so it lost all the vacuum ports. So I removed all the emissions sensors off the firewall and cut the plugs off and went through the DTC in link and shut my CEL off but it comes right back on for the same reason next time I start the car, so is there anyway I can't shut the CEL off and it will stay off? Thank you for any help
Did you make sure to check the "ignore CEL from this source" box, or are you just clearing the code?
It's in the DTC tab, right under the reported DTC's box. Just check the box that for whatever code types you don't want popping up a CEL.
