CEL flashes - which codes?
ukrkoz
30
Jul 2, 2008
tukwila, Washington
Hi all
I have 95 Eclipse 2.0L engine, manual
CEL produces these flashes:
1 2
3 5
5 5
I can not find anything like it in Chilton. Mof, for 95-98 engines, Chilton gives OBD2 codes, but this car does not have OBD2 connector, unless I am totally blind. It was made February 1995.
I read flashes several times, pretty sure it's written right.
What do those mean? Please?
the "12" code just signifies the start of the code reading process and that within the last 5o starts the battery has been disconnected (although i have never not gotten code 12 at the start)
(edited read the table wrong) the "35" code is code P1490 and P1489 Low speed fan control relay circuit and High speed fan control relay circuit
the "55" code signifies the end of the code reading process
this link will tell you the corresponding codes if you need in the future http://www.2gnt.com/index.php?d=PCM Error Codes
OK, many thanks... so what do I fix? Car does not overheat at all, fans run fine? But I'll be replacing radiator some time next week anyway, as its neck is crumbling.
