CD Player help
how did you hook it up to a battery???
all car stereos have a constant power that routes directly to the battery and a secondary power line that routes through the ignition so that the stereo will turn off when the car is off. The ignition line is usually the red wire and the constant is yellow or orange most of the time. Did you check the fuse?? A lot of higher end stereos will have their own separate fuse built in somwhere on the back with a cover that screws off.
there is a yellow and black.. i took the yellow to pos, and black to neg.. checked all fuses and everything, still nothing.. any suggestions? :cry:
yes...there is another wire that needs power. Look on the schematic that came with the stereo and find the ignition wire..that needs to have power as well...otherwise the stereo thinks that the car is off.
yes....that's what i was trying to tell him. There's a red (12V power) wire as well. You can't just hook up the constant and have the stereo turn on
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
