CAS Plug Wires
sholace29
46
Mar 21, 2005
Montpelier, Idaho
Hey can anybody please help me find the order of the wires to the pulg for the cas on a 98 GST ontop of the valve cover. Here is a pic of the one i need. I Need to know what color goes where so i can sodder the wires to it becasue i cant find the plug and the junk yard wants 150 for the wiring harness.
this might help a little, this is for a 1g 92 CAS...
pin 4 is the ground, test the continuity between the wire and a ground on the frame
pins 1 and 2 should get between 4.8-5.2 volts when the ignition switch is turned on and the negative test lead of the multimeter is grounded to the cars frame.
pin 3 should read ~5V when the negative test lead of the multimeter is grounded to the cars frame.
luv2rallye said:
On a 98 the CAS (camshaft angle sensor) has a 3 wire plug. Pin 1 has a black wire to ground, pin 2 has a blue/red to the ECU pin 88, pin 3 is red to the MPI relay (which also powers a dozen other sensors).
Thank You so very much That is exactlly what I needed
