cas help
SmashingDsm
71
Jun 12, 2010
palmdale, California
hey guys whats up i have this issue my car idles fine when on park and when i put in gear it drops idle to like 700 or lower i checked timing ,leaks and its all good any other ideas oh and the check engine light on and i hooked up my laptop to check it out on dsm tuning and it said cam angle sensor malfunction could that sensor be bad or what ?
thanks let me know if u have and idea on what to check i re checked boost leaks no leaks fixed all :D
ha-ha yea im going to do that anyways but can that fix my rpm dropping or i could check my fuel system?
by the way i got a 255hp pump with stock maybe good regulator and stock injectors and fuel rail :D
From what I read and what others say, if you run a 255 fuel pump you need a fuel pressure regulator because to over loads the stock one. Not sure that will fix your problem though.
that is a good question. i would assume they are there for a reason you might try to reattach them and see if it helps worse case your out about 5 min worth of time.
