Resolved Cars Getting No Fuel/Dead Fuel Pump (?)
Zephyros91talon
Mar 3, 2009
Pueblo, Colorado
Alright so here's the deal... My father and I rebuilt my motor last year and got my car running around November. Around new years I installed the fuel pump rewire kit. Everything ran perfectly fine for about 10k miles. A couple months ago, on two occasions, I turned off my car at a gas station to run in for a drink, and when I came back out my car wouldn't start. Both times it started up a couple minutes after so I figured it got a bad o2 reading or something and was flooded.
Then about a month ago I drove to subway to get some food and when I came out, my car would fire up, hit idle speed, then die literally less than a second after. It did this for a while until it would crank and crank but not fire up. I went back the next day and ended up swapping fuel pumps and it ran fine. Since then it would fire up instantly and not have any problems.
Today, I decided to go to the gym. On the way I stopped and got $15 of fuel. After that I decided to do a couple donuts in the dirt on the way to the gym, which didn't happen because the dirt lot I picked was way too bumpy. Right before I got there, I had heard a rattling that I had never heard before (I started freaking out thinking it was the turbine hitting the insides of the turbo since I bought some used small 16g).
So anyway when I get done with my workout (2.5 hours later), I fire up my car, which fired up flawlessly, and did around 10 small rev's to see if I heard anything (which I didn't). I turn her off, and then a couple minutes later I try to fire her up and the same thing happens to me that happened at subway. It would fire up for a second and die. Out of nowhere, something happened within a few minutes to stop my fuel pump from working. I left my car and returned later thinking it may just be vapor locked, but no. I pulled the fuel line going to the fuel rail and there was nothing. The fuse on the fuel pump rewire was good. Also when I turned the key on, the fuel pump rewire relay made no click.
I did search and one person said his messed up alt. pigtail caused his no fuel issue, which my alt. pigtail is a little messed up too, but I wouldn't see how that's causing the problem if the relay isn't working. Another person said the stock fuel pump wire which activated the relay got fried so he had to run another one from the battery. I'm going to go back tomorrow and check all the wires with a test light. Does anyone else have any ideas of what I should check tomorrow? Could my 10ga wire from the rewire kit be grounding somewhere after the fuse and killing my relay/fuel pump (I was an idiot and put the fuse under the hood and not closer to the fuel pump)?
Any input would be greatly appreciated. And also thanks for your time reading my long story, I tried to provide as much info as possible
Solution
I used the STM re-wire kit. So today I took a test light to the power source and found out that the inline fuse was not completely connected and was making the test light flash when messed with. So I went and changed it out with a whole new inline fuse. The car still wasn't starting and I eventually found out that the relay pigtail was also having the same problem. The wires in the pigtail were sliding out of the pigtail!
Anyway I fixed those two problems and everything runs fine now. I can't complain too much about the STM rewire kit since it was only $30 but with everything that's included, you do get what you pay for.
It was just interesting how my car died only after I stopped running it and it never died while driving. Also it...
since you check and theres no fuel its def your fuel pump. try using your old one see if it work. what type of fuel pump do you have. if you have the walbro than you should hear a whinny noise when you turn on the ignition. check your ground wire. retrace all wires see if one is loose. you can check the fuel pump relay see if its fried or not. check the fuel filter. most time these filters clog up. just make sure the fuel pump goes back in as it came out. all seals in same place. hope this help.
The hubbys gst died on him one day out of nowhere. He wasn't getting any power at all (no lights or anything) and it ended up being his engine fuse. Just a thought though. If you're not hearing anything when you turn your key then I suspect your fuel pump isn't getting power at all and I would look at wires and relays.
It was just interesting how my car died only after I stopped running it and it never died while driving. Also it makes me wonder if the fuel pump that I had changed out was actually in fine condition. Oh well I had another one sitting around.
I'm going to go ahead and blame the poly motor mounts for everything. Darn car is rattling apart now :p (but still worth it in every way)
Thanks for everyones input
Solution
  • For sale 2g 2G AWD Fuel Level Wiring Harness
    2G AWD Fuel Level Wiring Harness $35 + shipping and paypal fees* removed from 97 TSI AWD * all...
  • For sale 2g 2G OEM Passenger Door Handle
    2G OEM Passenger Door Handle $25 + shipping and paypal fees* the seal and two mounting bolts...
  • For sale 2g 2G OEM Interior Silencer Pads
    2G OEM Silencer Pads $20 + shipping and paypal fees* these go behind the plastics to the left...
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
