Car wont start on its own
Circus805
45
Apr 20, 2003
Lompoc, California
96 Eclipse GS, Manual.
Wont start but i can pop the clutch and it runs fine, kinda. Seems like there is a timing error and there are alot of popping when i first get it started. Does timing affect ignition? I do not hear the starter even trying to turn over. Help?!!?
-James-
-James-
Timing does affect ignition. If you jumped time, then your valves arent opening at the correct intervals you're also looking at severe damage(bent valves). When starting are you talking about a rolling start in second gear? It does sound like a bad starter if it will only start with a rolling start. But it also sounds like your have deeper issues. Have you checked your plugs/wires/coil pack recently? Start with thesimple stuff first. Change that and then do a rolling start again, if it runs good after that, replace the starter,if it doesn't take it to the shop.
