1G Car won't start, Ignition?
crowa95
Jan 7, 2023
PERU, Indiana
Hey yall, so my car won't star and I think it is the ignition, and I don't have a clue on what's wrong. It gets fuel and I'm guessing it gets air. It has the 2.0l non turbo, any help would be amazing.
Yes I have them but need to put them on, also was wondering if there was a chip that controls the ignition?
Exactly what car do you have? I get that it's a 2.0l non turbo but what year and model?
1992 Mitsubishi Eclipse GS, 2.0l non turbo, 5 speed manual. Been sitting since at least 2011, plate I think says 09 or 10
You have a lot more work to do. Does the check engine engine light come on with key on then go off in 5 sec?
Pull the plugs and smell them. If they don't smell like fuel then you don't have any. This does not mean your pump isn't working. It just means you have no fuel in the cylinder. Tell us what you find. Actually, you're sure all the timing belt items are intact? The car has compression?
Ngl, idk about compression and I did make sure the timing stuff is intact and it don't make any wierd noise when cranking
Ok, ignore any references to the 420A as you browse the site, you have a 4G63.
Paul asks a key question, "Does the check engine engine light come on with key on then go off in 5 sec?". This tells us if the ECU is functioning which is a requirement for anything interesting to happen.
1992 mitubishi eclipse gs, 2.0l non turbo, 5 speed manuel. Been sitting since at least 2011, plate I think says 09 or 10
This changes what I said about 420a.
Like steve says make sure ECU is working. Do all your maintenance items. Then you can look at fuel and spark.
Sitting that long you can have lots of little stuff going on that add up especially in your fuel system.
Hey guys, I was wondering where the crankshaft sensor is located and if it could cause my car not to have spark or fuel?
In a 1G 4G63 NA like with the Turbo 4G63's you have a CAS that provides both the Crank and Cam positions to the ECU.
The most typical cause of no spark or fuel is that the ECU isn't working.
What diagnosis have you done that pointed at any of the parts you have changed?
Do any of this?
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
