Car Won't Idle
ohlegend
581
43
Apr 2, 2012
Pemberville, Ohio
Ok, so before I fixed my boost/vac leak, I was able to idle the car for 30 seconds. If I unplugged the MAF, It would idle between 800-1000 and it would not cut out.
I found a huge leak at my intake manifold, replaced the gasket and mounted everything back on the car. (All vac lines and connectors are connected). Now, I turn on the car and it will run for 20 seconds or less and die. I did another vacuum test and it did not leak. So I have come to the conclusion the it could be one of the following things:
ECU
Not enough spark
Low Fuel pressure (bad FPR)
If I give it some gas it lags for a bit, backfires and then revs up.
Any ideas? Am I on the right track?
I have new battery terminals and another ECU on the way. - FYI
It sounds like the opposite to me. Backfiring when reving is because of excess fuel. Backfiring on decel would be a lean condition.
Are you throwing any CELs?
It still sounds like you have a big boost leak to me.
No CELs. Boost and vac tests passed. There is nothing leaking anywhere from the intake manifold back. I also got the BOV to chirp. - I dont know if that helps or not. I will be checking over everything again this weekend.
It still sounds like a boost leak even though you've performed the test. I wonder how your doing it. Do you have the vacuum line from the fuel pressure regulator hooked up to the intake manifold or fp solnoid?
From what I can tell so far, the cam or crank sensor is having a hard time communicating with the ECU which would explain the random, abrupt shutdowns. Take a quick look at them to see if there's any damage.
My car idles smoothly at a constant 500 RPM. I think that's where it is supposed to stay at.
I believe the idle speed is set by the ecu at 750 rpms. A 100+/- is considered normal.
I am pressurizing the intake elbow to see if there are any leaks at the throttle/manifold.There are not any. My friend also brought up that there was 1/8 of a tank of gas that had been sitting in the car for 2 years. I added another 1/8 tank of premium and a little bit of octane booster. Could the problem be that my octane level is too low?
In that case, you need to add a can of sea foam and then put at least four gallons of fresh premium gas in it. Don't add any more octane booster.:thumb:
Also its better if you do a boost leak test from the turbo. So you can see if you have any leaks around your intercooler piping. You can make one for like 8 bucks from lowes or home depot.
I was able to pull data from the car while it was running:
Live Data
Number of DTCs stored in this ECU 0
Fuel system 1 statusOL-Drive
Fuel System 2 status--
Calculated LOAD Value(%)0.0
Engine Coolant Temperature(¡£C)16
Short Term Fuel Trim -Bank 1(%)0.0
Long Term Fuel Trim - Bank 1(%)0.0
Engine RPM(rpm) 0
Vehicle Speed Sensor(km/h)0
Ignition Timing Advanece for #1 Cylinder(¡£)5.0
Intake Air Temperature(¡£C)4
Air Flow Rate from Mass Air Flow(g/s)6.10
Absolute Throttle Position(%)0.0
Location of Oxygen SensorsB1S12--B2S----
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)1.275
Short Term Fuel Trim Bank 1-Sensor 1(%)0.0
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.060
Short Term Fuel Trim Bank 1-Sensor 2(%)0.0
OBD requirements to which vehicle is designedOBDII
Calculated LOAD Value(%)30.2
Engine RPM(rpm) 902
Ignition Timing Advanece for #1 Cylinder(¡£)19.0
Air Flow Rate from Mass Air Flow(g/s)4.73
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.080
Calculated LOAD Value(%)23.5
Engine Coolant Temperature(¡£C)17
Engine RPM(rpm) 839
Air Flow Rate from Mass Air Flow(g/s)5.05
Calculated LOAD Value(%)23.9
Engine Coolant Temperature(¡£C)18
Engine RPM(rpm) 882
Ignition Timing Advanece for #1 Cylinder(¡£)18.0
Intake Air Temperature(¡£C)3
Air Flow Rate from Mass Air Flow(g/s)4.96
Engine Coolant Temperature(¡£C)19
Engine RPM(rpm) 851
Air Flow Rate from Mass Air Flow(g/s)5.07
Engine RPM(rpm) 898
Air Flow Rate from Mass Air Flow(g/s)5.06
Engine RPM(rpm) 847
Air Flow Rate from Mass Air Flow(g/s)4.89
Calculated LOAD Value(%)27.5
Engine Coolant Temperature(¡£C)20
Engine RPM(rpm) 691
Ignition Timing Advanece for #1 Cylinder(¡£)21.0
Air Flow Rate from Mass Air Flow(g/s)4.46
Modules Present
$00: ISO 9141-2
Had a similar issue and it turned out to be a combination of bad fuel and a loose MAF connection.
I also put a new Walbro pump in a few months back when I bought this car.
I have not had it out to drive yet.
I can hear it when I start the car, but I dont hear it after that.
Maybe my car in running off the initial pressure, then when that pressure dies down, it stalls out?
What fuel pump? 190? If its rated more than that you need a FPR. Really sounds like fuel delivery issue.
The 255 def requires a aftermarket FPR. Aeromotive is a really popular/reliable brand. Also don't know a whole lot about the data that you logged but is it showing 19* advanced timing?? wouldn't that be a lot? someone else would have to chime in on that.
Ok so we got the car properly timed and we are still having issues. We noticed that it felt like there was back pressure, it smelled rich, and black stuff was coming out of the exhaust. The car chokes its self out.
Do you guys think that maybe the cat. converter is plugged up or the muffler?
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
