Car won't go into reverse with shifter.
sapper12b
71
Mar 7, 2013
St. Robert, Missouri
I have a 1990 GST. I just replaced the 6 shifter bushings because my shifter was sloppy as all hell. Before doing this, my car would not go into reverse from in the car. I always have to pop the hood pull up and then towards the front of the car on the shifter cable where it attaches to the tranny. Goes in everytime, no issues. What I wondering is why the hell is it doing this? Someone please chime in and give me some advise. And for the record, the new bushings are amazing, goes into 1st - 4th like butter without missing gears.
Awsome, i actually just read over that faq and i will be doing it in the morning. I will let u know the results. Thanks man.
I tried to do like the faq says. The problem i am having is that when the shifter is centered, the cable closest to the driver doesnt line up exactly, its about 1/4" too long, i cant shorten it anymore to line up perfect. I am correct by doing this all while in neutral? Also, it will not go into 5th now, which leads me to believe it must be the linkage.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
