car running lean what could it be
talontsi81
40
Feb 8, 2009
Central, Pennsylvania
we tried every sensor possible and nothing the only thing i didnt try was a knock sensor fuel filter and fuel pump its running lean and spits and sputters more when i build boost when im just idealing its fine any ideas
Check for vacuum leaks, o2 sensor, Mass air flow sensor, fuel pump, and fuel filter. Those can all affect A/F ratio's.
Did you check your spark plugs and at what gap they are at? Throw in a fresh set of NGK BPR6 or 7's gap to .028 and check your plug wires, and as stated above, do a boost leak test.
How much boost are you attempting to run on a stock fuel system?
