Car Running Awful
The4g63tKid
Nov 13, 2009
San Juan, Pennsylvania
HI Im New Im From Puerto Rico I need Help With My 91 Talon I Don't Know Whats Wrong With It The Car You Start It And After A Minute Or Less The Car Wont Go Accelerate After 10 Vac Its Like Is Cutting The Fuel When You Acelerate it When You Start it You Step On It An The Car Boosts Well No Boost Leak At All But Later It Wont Almost Run I Need To Fix That Proble ### its My Only Car And I Got Fired Andd I Need A Girl And A Wife WhoS Life Depend On Me The Car Doesn't Have An O2 Sensor But It Wasnt Doing It Before So I Guess Its Not That I've Been Running It Like That A Long Time Even Before I Rebuild The Engine Any Opinions Questions About It Or Anything Is Useful Thanx :idontknow: :talon:
Here's A Video Really Bad quality ### I Did It Outdoors And Almost No Light But Listen When I Acelerate How Does It's Driving Me Crazy
http://www.youtube.com/watch?v=6Gn2JNDpvnE
When I Rebuild the engine the engine was running great but it started giving me this problem because the car i dunno why one of the balls from the transmission The Thing With The Three Balls I Dont know How You Call It Broke Or Got Loose The Thing Is I Changed The Shaft i fixed it the I Acelerate the car to almost 3500RPM And Took off WOT Bu then There Is The Ground Cable From One Of The Coolant Sensors The One On The Tstat Housing The Upper One I Have To Have It Connested To Ground Or Else The Car Will Run Really Rich But Still The Car Was Running Great Like I Said After You Start It The car Boosts Well No boost Leak Or Anything Checked vaccums And Intercooler Pipes Everithing Is There Anyway You Can Reset The ECU Or Erease The Codes Just In Case Thanx Ill Keep Looking Around For Any Help
