car not accelerating and breaking up blt done
jbeaton9292
847
75
Aug 29, 2013
Sterling heights, Michigan
well like the title says my car in 1st i can get up to 20mph so around 3000 rpm and then it starts to break up and sounds like anti lag so obviously i let out but this isnt even when making boost it does it regardless i did a blt up to 20 psi im only on 13psi for now still tuning i have a boost leak at the injector seals not that bad at all though and i dont know why its doing it i changed the plugs wires coil ptu everything and it is still doing it and now im stumped
it runs great up till that point and 3rd gear does the same at 55mph :notgood:
list of mods
jmf race
built upper and lower end
hx35
2g mani with external gate
1g bov
vrsf fmic
stock tb
3" exhaust
if you need more info just ask ill be more that happy to give any and all info that might be helpful thanks in advance for any help its greatly appreciated
So what are you tuning with? Sounds like it's knocking all over the place...?
Using link v3 full and my knock sensor is not working properly hense why i havent tuned for any more or try to make boost and its holding steady 5* timming i know i need this fixed but short on cash right now
Does anyone think maybe a crappy fuel pump rewire would cause this previous owner has it done with speaker wire and dont look very good
