Car keeps cranking but won't start
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
Alright so I am having a hard time with my 96 eclipse rs.
It started fine before but had the wrong fuel rail. I changed the fuel rail and took out the 1/2 put together security system out and now it won't start.
does anyone have a diagram for the ignition setup in these cars? (under the steering wheel area)
Constant 12V+ White Ignition Switch Harness
Starter Black/Red Ignition Switch Harness
Ignition Black/White Ignition Switch Harness
Ignition 2 Blue Ignition Switch Harness
Accessory Blue/Black Ignition Switch Harness
Tach Black/Blue Or Blue/Black Coil Pack (2 Cylinder Setting)
Neutral Safety Wire Black/White (-) PCM behind Center Console
Brake Switch Green Brake Switch
Trunk Pin Red/Green Silver Driver's Kick Panel
Parking Lights Green/White (+) Driver's Kick Panel or Fuse Panel
Head Lamp Red (-) Light Switch
Factory Disarm Green/White (-) Driver's Kick Panel
Door Trigger Red/Green (-) Courtesy Light or Driver's Kick Panel
Door Lock Brown/White (-) Behind Fuse Panel or 20 Pin Connector High Driver's Kick Panel
Door Unlock Brown (-)
Driver's Lock Blue/Black Driver's Kick Panel
Driver's Unlock Blue/Red Driver's Kick Panel
Passenger Unlock Blue/Red Passenger's Kick Panel
Horn Wire Green/Red (-) Steering Column
Windows Up LF=Green/Red, RF=Brown/Yellow
Windows Down LF=Green/Black, RF=Green/Yellow
I thought this may help.
1995-96 Mitsubishi Eclipse Alarm, Remote Starter, Keyless Entry Wiring Information
