Car jerking/bucking help please
Iryoku
93
May 31, 2005
Brooklyn, New York
When I floor the car and hit 4500-5000rpm's the car starts jerking/bucking. A/F ratio is good to go ( think). I dont see/hear any vac leaks (is there a certain way to do this?), what else can cause this?
what should i look for?
I cant figure out the problem.
Thanks in advance!
no blow off valve... any aftermarket pieces are listed in my profile.
no i dont think its crushed, no reason for it to be its been fine and i never touched it.
I am running 15-16psi
is the jerking/bucking like a jerk forward in acceleration or does it feel like the engine stumbles? from what gathered from your info, i would check your ignition components. my car would stumble after about 3500 rpm espescially when i would tromp on it. it turned out to be a $50 fix of spark plug wires.
Man I read this and for a sec I thought you were like one of my smartass friend who thinks his stock wrx turbo can hold the amount of pressure in it that he doesn't need a bov. then I read on.. aah LOL!
oh btw ppl tend to overlook this but it might be ur gapping too? ;)
A) What kind of spark plugs do you have and what are they gapped at?
B) You've got a 255 lph fuel pump. Almost 3x more than stock. You need a fuel pressure regulator.
NGK 7ES spark plugs
fuel pressure regulator? what does that look like?
forgive me im still a newbie as you can tell LOL
And i believe my plugs are gapped 2.8
I just put my car back to stock boost 10psi i believe... and the bucking stopped. Anyone have any idea what that might mean? hehe
You probably have a boost leak at a pressure above 10psi. Go through your engine bay and inspect each and every intercooler hose and tighten the clamps and see if your problem goes away.
Build yourself a pressure tester, that will tell you exactly where the leak is coming from.
